add phase to the sinusoidal signal
Hey everyone,
I have issue. I don't knew how can i add phase to the sinusoidal signal? I have two sinusloids whith are of variable frequency (variab. freque. - i suppose that is not a problem for solve my problem). Tension and curant (my two sinusoids) i need delay each other.
 If anyone can give me help, please.
Marek
Message 1 of 8
(4,255 Views)
hi,
  If you are generating a sine uisng express vi,phase input is there.wire any value to it and get the delay...
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 8
(4,242 Views)
Thanks SrikrishnaNF for your reply,
These sinusoids I've taken from sensors and i need edit them.
Message 3 of 8
(4,231 Views)
Hi ,
  If that is the case...please check the delay values express vi...
Thanks and regards,
srikrishnaNF
Srikrishna
Message 4 of 8
(4,224 Views)
Hey SrikrishnaNF, if you mean whot i insert previous it doesn't work. After diagram run is appered an error that two signal are not the same. And i think that it is not a delay of signal phas.
I calcul the paramet reel and imaginary from two singnal. For my experience i need delay with phase one signal unto the second.
Message 5 of 8
(4,199 Views)
Hi gfds,
Maybe you can use cross-correlation between your signals.
Message Edité par Micael_ le 10/05/2010 03:16 PM
Cordialement,
Micaël DA SILVA
Message 6 of 8
(4,187 Views)
Thank you Micael_ for help
How can I use cross-correlation block for solve my issue?
I've attached my resultat of using this block. Frequency is in range 25kHz - 35kHz with showing resonance.
Message 7 of 8
(4,173 Views)
I thougth you wanted to calculate the delay between the sinuses...
If you want to add a delay, you can just acquire a little more samples and then remove a part of the signal at the beginning of an array/the end of the other.
Is there a problem with your current acquisition? It seems not to be a sinus.
Maybe it would be more convenient if you post your question in the french forum.
Message Edité par Micael_ le 11/05/2010 09:20 AM
Cordialement,
Micaël DA SILVA
Message 8 of 8
(4,143 Views)
