add .exe file in labview 8.6 installer
Hi all
I need to create an install package for a LV8.6 application.
The problem is that the application needs a .exe external file. How can I add it to the installer?
I put it into the same dll directory but in Build Specifications/<My Installation>/Source Files/Project view only dll are correctly shown.
May I put the .exe manually into the package?
(2,637 Views)
Accepted by topic author Markku_B
You need to actually add the file to the project. Did you do that?
(2,619 Views)
Thank you Dennis, as simple as that!
(2,601 Views)
