add data from DAQmy Read (Analog 1D Wfm NChan NSamp) to shift register
If I try to attach the file I get the following error:
The contents of the attachment doesn't match its file type.
Message 11 of 15
(1,193 Views)
Accepted by topic author avstenit
About that upload error! It's well known and that error exists for a long time…
On your specific VI problem:
The "before append" indicator shows an empty array because you initialized the shift register with an empty array!
You need to:
- initialize the shift register with a non-empty constant
or even better:
- handle that special case of empty input seperately!
Message 12 of 15
(1,188 Views)
I have written some explains about the for loop behavour and I have also attached the link to the file, if one could maybe take a look.
Message 13 of 15
(1,183 Views)
Thanks! Well I think if I initialize a shift register with non-empty contstant this data will get appended and modify the real measured that is not ok. So I think that I should go with case structure to check if shift register is empty or not - am I looking in the right direction? How can I check if shift register is empty?
Message 14 of 15
(1,180 Views)
Hi avstenit,
look into the comparison functions palette. There used to be a function to test for empty arrays…
Message 15 of 15
(1,170 Views)
