add AI Config.vi in Labview 7.0
I am new user of LabVIEW. I have LabView 7 and i want to develop Data acquisition application for PXI. I have also installed NI-DAQ but i couldn't add analog input block like "AI Config.vi, AI Start.Vi etc" in my application. I might be installed NI-DAQ wrongly or i may need to install some thing (Library) still not installed. Can any one suggest to how i can install these component and how i can call in my application.
--Vishnu Patel
(5,304 Views)
Hi Vishnu,
These AI Start, AI config  are a part of Traditional DAQ. Just check if you have installed the traditional DAQ Device drivers correctly
Which DAQ card are you using??
Coz if you are using a DAQ card that is compatible with DAQmx, I would suggest you to Install the DAQmx version compatible with LabVIEW 7 and proceed
Find which NI DAQ Driver version is compatible with your LabVIEW version from Here
This link will tell which DAQ Driver version supports your DAQ hardware
This , this and this tutorials will help you to get started with DAQmx
Any doubts, do ask
Dev
(5,296 Views)
Hi Devchander,
    I am using NI-PXI8176 controller with NI-PXI 6071E multifuction I/O card. and i have installed traditional DAQ, Is it needed to installed DAQmx?
(5,290 Views)
Technically speaking, your Hardware ( E series DAQ card) is supported by both Legacy Traditional DAQ and DAQmx
Since your hardware is supported by DAQmx, I would 'Advise' you to go with it, for the obvious advantages it has over the Legacy DAQmx
Also read the links I had sent in my previous post to understand the benefits of using DAQmx
(5,285 Views)
Dear Dev
Thanks for guidance. I got right type of DAQ and installed it not i have AI vi s
With Regards
Vishnu Patel
(5,268 Views)
Good to hear that, Vishnu.
But do explore the DAQmx functions and programmming as well Smiley Wink
(5,260 Views)
