adam card communication problems
Hello
I work in C C Engineers,pune.We have used Adam cards for communication,e.g.4055,4056,4019 etc.
I am simultaneously reading inputs from cards and giving output to them.The data coming from ADAM cards are converted to serial data through ADAM 4520 and is given to PC.
The problem i am facing is if i press one button(Push button),sometimes it shows on software immediatly..but sometimes it does not.
When i went through datasheet,i found that ADAM 4520 is HALF DUPLEX.Can it be a cause of the problem?Because speed of accesing inputs and giving outputs is fast from my softawre.Can you please  help me ?
Also,is there any FULL DUPLEX card which i can use instead of  4520?
P.S: I am accessing and writing data through the cards simultaneously.
Thank you
GAK
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,377 Views)
Frankly, it doesn't sound so much like a communications problem as it does a software structure problem. Can you post some code demonstrating the problem?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,357 Views)
hi mike
I am attatching communication file now..check if you find any problem.
Let me tell you that m not sending and recieving data from one VI there are 4 parallel vi's .
The communication file is also in while loop so as to constantly update values and there  are 7 adam cards for analog and digital I/O
Waiting for your reply
thank you
GAK
Message Edited by gak on 01-30-2009 09:54 PM
Gaurav k
CLD Certified !!!!!
(3,349 Views)
Accepted by topic author Gak
hi,
reply please.I am waitiong for your reply.
GAK
Gaurav k
CLD Certified !!!!!
(3,310 Views)
