05-29-2008 09:40 AM
05-30-2008 01:28 AM
05-30-2008 07:07 AM
05-30-2008 07:10 AM
05-30-2008 07:35 AM
05-30-2008 08:56 AM
06-01-2008 11:14 PM
Hi Yiannis,
Here is the code Mike posted, saved for LabVIEW 7.1.
06-02-2008 03:14 AM
Jennifer hi and thanks for your help.
A quick question : Did you open the vi at all when you saved it for LV7.1? It gives me two errors when I think it shouldn't..I was wandering if it has anything to do with the differences between Version 8 and 7.1...
Thank you very much for your time...
Yiannis
06-02-2008 03:16 AM
Hi I_Pant,
which errors do you get?
Mike
06-02-2008 03:22 AM
Hello Mike
It gives two errors one in the "false" case at the Invoke node of Workbook (unwired or bad terminal), and one at the "true" case at the invoke node of workbooks (unwired or bad terminal). It seems to me that it has something to do with the filename you are passing. I am trying to work it out now, the problem is that it looks right to me!.
Anyway Mike I really appreciate your effort, thanx again...
