activex containers provide
hello,
I would like to know as can I Activex container provide.
so that I can call all the same which .exe datein.
thanks
(2,528 Views)
If I understand you right, you want to access a VI that you programmed via ActiveX. It is not possible to build your VI inta a ActiveX-Control, so that you can use it in an ActiveX-Container, but you can build an executable out of it, that has a ActiveX-Interface, so it can be used as an ActiveX Server.
Another way would be, to use the ActiveX Interface of the LabVIEW development environment, to call the VI directly:
Hope this helps!
(2,511 Views)
