activating windows screensaver
Hi
I'm trying to activate the windows (XP) screensaver from LV6.1.
I've tried the Windows API Function Utilities (32-bit) for LabVIEW as previously suggested, and used "Start Windows Screen Saver.vi". However I get an error that the library function "LVPostMessage" called by "PostMessage Master.vi" is not found. Is there a problem with "LVWUtil32.DLL" file I have or am I missing something?
Roo
(3,516 Views)
Hi
There is another way to activate screensaver, easier than the use of dll.
Just use the "system esec vi". The input command should be    YourScreensaver.scr /S.
If screensaver is not in a windows directory, type the full path.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,504 Views)
Thanks - much simpler and works perfectly.
Cheers
Roo
(3,487 Views)
Can you please attach the vi or the .png of your code.
thanks
sreedhar.
(3,481 Views)
Hi
See attached image for all the code you need. Change "Helios.scr" to whatever your screensaver is called (scr files reside somewhere like C:\WINDOWS\SYSTEM32". Alipio actually meant "System Exec.vi" which is part of LabVIEW.
Roo
(3,461 Views)
