activate thermotron from labview
I am trying to communicate with Thermotron Chamber(TH8800 Controller) via serial comms, I downloaded Thermotrons VI's but did not get them to work - I receive erros!
Perhaps I have not configured the 8800 controller correctly for receiving serial comms from a PC - can someone please tell me exact steps i must ensure are set on controller to ensure correct operation via serial comms,
Should i only have Serial Comms selected in 8800 computer I/O and must every command sent to chamber end with special delimiting charatcer?
Message 11 of 19
(2,277 Views)
Hi
Did yo get the required help with this, i have a similar task with a thermotron chamber that has a 7800 controller. i would like to control it using labview, but i need exact step on the process to do so. any help would be appreciated
Thanks John
Message 12 of 19
(2,141 Views)
hi,
i dealed with this 8 years ago so i don't have the code any more.
please see the example VIs i attached on the first page of the post. it may help you to havr a start.
amos
Message 13 of 19
(2,123 Views)
May be a day late and a dollar short but i'm using the Thermotron Supplied Themotron SubVI's I will Attach them. I simply modified these files to accomodate any data aquisiton going on as well and restructured the commands into tabs.
Hope it Helps
Sincerly, Billy G. Alexander
Message 14 of 19
(2,082 Views)
Your not as late as me!!!
These subVI's are for a TCP\IP connection what is involved in changing this to a RS232 coonection or is there a completely different set of VI's for this type of interface
Hope you can help
John
Message 15 of 19
(2,007 Views)
Hey,
        I think we can re-animate this dead animal.
I Went back an looked through my folders and found the attached Drivers. You will need to move the supplied DLL's into the appropriate location's but that should be an issue
I took a quick look in the library files they use a standard I/O so you can just point it to a Com address for your RS232
Message 16 of 19
(1,993 Views)
In the attached installation instructions, it said to put the .dll into C:\VXIpnp\WinNT\bin, this directory doesnt exist . is it just as simple as creating this directory and putting the .dll file into it?
Message 17 of 19
(1,975 Views)
I am using a USB to Serial connection, with a 3 null RS-232 cable.
I have downloaded the drivers and placed the file in the correct location and mass complied as per instructions.
I have also placed the .dll file into the correct file which I created
Next I am trying to send commands through the visa test panel but I am still receiving a time out error
Have you any ideas were I am going wrong.
Message 18 of 19
(1,953 Views)
Duplicate - http://forums.ni.com/t5/LabVIEW/Thermotron-Chamber-controlled-by-Labview/td-p/2348620
Please stick to one thread. Multiple posts of the same question only serve to confuse and irritate.
Message 19 of 19
(1,950 Views)
