action on control click
Hello everybody
I have a simple numerical control. When value is changed by click
I would like to take some action. Is there any simple way to
check if the control was changed, I am thinking about some
"elegant" solution, someting like action on press?
regards
PP
Message 1 of 8
(3,766 Views)
What LabVIEW version you use? If you use 6.1, there is Event Structure, that very easy for using. There are examples in LV help.
If you use previous versions of LV, you must check value of control, if it changed.
Another approach is to put ActiveX numcontrol, for example CWNumEdit of NI and use ActiveX event (valuechanged)
Look attached examplewith 2 approaches.
Hope that helps.
Nadav Chernin
nchernin@chiaro.com
Message 2 of 8
(3,766 Views)
Look this attached zip-file. Attached example in answer is not complete.
Message 3 of 8
(3,766 Views)
Thank you very much, it helped very much.
best regards
PP
Message 6 of 8
(3,766 Views)
I'm using LV6.01 currently but as far as I know there are some event-driven capabilities in LV6.1 And they allow you to easily check if control value was changed.
Another solution is to use something like state machine - the loop with shift registers connected to your control. So in every iteration you can compare the curent value of control with the previous one obtained from shift register. I've attached the example.
Good luck.
Oleg Chutko.
Message 4 of 8
(3,766 Views)
best regards
PP
Message 5 of 8
(3,766 Views)
In LV 6.1 you can do some explicit event handling. In older versions you
can't.
For my part I split up an application in a user interface and a processing
VI. Within the User interface I scan that contro repeatedly and send a
notification to the core when some action took place. That works fine and is
rather "elegant".
Oliver Friedrich
"Pawel Pocwiardowski" schrieb im
Newsbeitrag news:3CE20331.96A4D988@poczta.onet.pl...
> Hello everybody
> regards
> PP
Message 7 of 8
(3,766 Views)
numeric_event.zip:
http://forums.ni.com/ni/attachments/ni/170/28338/1/numeric_event.zip
Message 8 of 8
(3,238 Views)
