acquire multi channel in labview from DPO2024
I am trying to acquire signals from multiple channel and view them in the same graph. I tried but failed each time. Any help will be appreciated.
(3,067 Views)
I can't look at your VI since I am posting from my phone but the basic technique is to configure both channels, initiate, READ channel one, then FETCH channel 2. Combine results to single graph.
(3,061 Views)
I tried the same. But I guess I am having problems with the combining part. !
(3,051 Views)
Thanks, I found  a way out.
(3,043 Views)
Can you post an image off the block diagram? Are you getting two separate waveform data types? You would just use a build array and wire the result to the graph.
(3,042 Views)
