acquire data without sampling rate using DAQ?
Is there any way to acquire data using DAQ without sampling rate?
Message 1 of 9
(4,062 Views)
Are you looking for this example?
C:\Program Files\National Instruments\LabVIEW 201x\examples\DAQmx\Analog Input\Voltage - SW-Timed Input.vi
Certified LabVIEW Developer
GCentral
Message 2 of 9
(4,037 Views)
Could you please post that link?
Message 3 of 9
(4,032 Views)
In that channel settings, is that possible to add physical channels instead of 1?
Message 4 of 9
(4,030 Views)
Dev1/ai0:2
or
Dev1/ai0, Dev1/ai3
GCentral
Message 5 of 9
(4,028 Views)
I cannot understand why do you want the link.
It's just file path.
GCentral
Message 6 of 9
(4,027 Views)
In LabVIEW, open the Example Finder (Help->Find Examples).  Look through the DAQmx->Analog Input and you will find this example.
Message 7 of 9
(4,014 Views)
In that also have to specify the sampling rate in "Acquire data" section.
Is there any alternative for this?
I need to acquire 2 channels of input from DAQ without specifying sampling rate.
Is there any solution for this?
Message 8 of 9
(3,983 Views)
Hi vim,
No, that example does NOT ask for a (DAQmx) sample rate!
It asks for the loop iteration rate (aka loop time): that's how the example works.
You can learn from that example on how to setup a DAQmx task and read samples without setting an explicit sample rate. Adapt with your own algorithm: apparently you want to read more than just one sample, so you will employ a loop with a certain loop iteration rate!
Message 9 of 9
(3,980 Views)
