acquire data using buffer
Yes I do actually want to acquire at 120MS/s ,i've just want to try this bloc ping-pong but i don't know how it works or how it is activated once i run my VI ,I'm just trying to find a solution for my problem .
Message 11 of 16
(1,382 Views)
if you see the picture that i've joined before it's an .exe that i want to recreate there is a "scan clock source " at double internal ,this mode allowed to the data to be sampled at 120MS/s , Do you have any idea how can i do that ?
Message 12 of 16
(1,381 Views)
Hi nasnas,
check the sources for that EXE. Or ask the one who created the EXE!
Or read the manual for your DAQ device to learn about its options. (Do you mind to attach the manual or provide a link?)
Message 13 of 16
(1,380 Views)
I don't have any sources of that EXE.  . I searched in forums they said that there is no way to get it . And the EXE was created by Labo i've contacted them they said that they don't have sources available for publishing .
you can find the manual attached .
Message 14 of 16
(1,370 Views)
Hi nasnas,
you attached the SpecSheet, but no manual.
That datasheet mentions some driver and SDK, also for LabVIEW. Get them from AdLink and create your own VI - after reading the manual…
Message 15 of 16
(1,368 Views)
i've read about shift registers and I tried to do my acquisition with and without them but it gives me the same results . It's not the problem as it seems , and with the Chart it doesn't work also .any idea please of how it could be solved ? because after that i want to get the enveloppe of my data to get the t1,t2,t3,t4 .
AS it shown in the picture.
Message 16 of 16
(1,346 Views)
