acquire data from DC powersupply in 2ms interval
Hi team ,
i am using the keysight DC power supply E36100  Using that power supply i need to capture the current , voltage ratings w.r.t. in interval of 2ms and plot it on the excel sheet .
i have done somethings . attached the program in screenshot .
Kindly guide me .
thanks in advance
(1,623 Views)
Hi willcan,
What is your question?
What is the problem?
Where is the "attached program"? There only is an image in your message: we cannot debug images with LabVIEW!
(1,582 Views)
You have a subVI with a wrench in it, inside the loop.  That symbol usually indicates some sort of configuration, and it will always run with the same data since they are constants or sourced from prior to the loop.
Do you need to run that subVI on every iteration inside that loop?
(1,570 Views)
How are you connected to your power supply?  Depending on the communication bus, getting a measurement could be taking more than 2ms.
(1,541 Views)
