05-25-2010 08:38 AM
Hi everyone,
I am using a 6551 to write and read an eeprom. It seems that if i feed the eeprom with 2.5V, the 6551 won't notice the "1s" in the signal; it's acquired as "Zs".
So i fed the eeprom with 5V, and i can write and read.
My question : is it possible to chose (more particularely here lower) the threshold of detection of the 6551?
Johanna D.
05-25-2010 01:17 PM
Use the niHSDIO Configure Voltage function found in Measurement I/O - HSDIO - Acquisition - Configuration palette. Two ways to set it up:
1. Set the polymorphic selector to Data - Custom Levels. Set the high level input to 1.5 volts and set the low level input to 0.8 volts
2. Set the polymorphic selector to Data - Logic Family. Set the logic family input (an enum) to 2.5V Logic.
