accessing array elements
Thanks  ,
now i undrestand the NAN function,Smiley Happy
Message 51 of 58
(3,253 Views)
Hello UliB,
may i know what meant by determinig the threshold width for the peak detector,what i found from LABVIEW Help it shouldnt be less than 3.
but i need to undrestand it totally,if you dont mind,please.
thanks,
Message 52 of 58
(3,242 Views)
can any body help me  please,Smiley Sad
why i can not connect the spreadsheet to thewhole block diagram,i need to read data from the spread sheet,
Message 53 of 58
(3,197 Views)
I don't understand your question.
What spreadsheet are you talking about?  Where is it that you want to connect it?  Is it truly an Excel spreadsheet or is it a delimited text file?
Message 54 of 58
(3,189 Views)
does anybodies know how to make some ecg simulation with sine signal (sine pattern) but without ecg simulator?
Message 55 of 58
(3,123 Views)
You should probably start a new thread. Good luck!
Message Edited by altenbach on 01-13-2009 11:38 AM
Message 56 of 58
(3,117 Views)
I have a data array. I need to input one element of this array to serial port in every iteration. I am using timed loop.
In other words, only one element of this array must be given to this timed loop on each invocation. Please guide.
Message 57 of 58
(3,048 Views)
Make the input tunnel autoindexing and stop the loop when you run out of elements.
Message 58 of 58
(3,042 Views)
