accessing RT MHQ from host
I want to use a NI myRIO to control several steppermotors on a test setup. Since the program should be very scalable, i use a MHQ structure to generate motion profiles and to monitor and control other hardware on the RT target
Now I want to access the program via a UI on a host PC. I can transfer data between RT and host with shared-variables. But how can I access the MHQ on the RT Target from the host PC?
Of course I can also transfer the message strings and data via shared-variables. But how can I assign the queue reference?
Is there a more elegant method for this?
Thanks a lot! Regards
Heiko
(2,512 Views)
You cannot access the queues and/or the queue refnums, that reside on you RT-target, directly from your PC host.
Regards, Jens
Kudos are welcome...
(2,479 Views)
