accessing NI-XNET APIs in Vector CANoe
I would like to call certain NI-XNET functions from Vector CANoe, thereby trying to communicate with the CAN driver from NI directly from CANoe. I know that it is possible the other way around (interfacing Vector CAN driver with LabVIEW ) using the DLL provided by Vector in LabVIEW. Here is a good description of it.
The idea is to use the NI-XNET DLL to access the functions in CANoe (CAPL). I know you can access the functions from a windows dll in CAPL. Unfortunately, I didn't find much description with regard to this topic.
Strangely, when I looked into the nixnet.dll, there were no functions except for the 'createXnetSysApiExpert' function. Any idea what this is? But there is this other dll, 'nixlvapi' which contains the functions which I am looking for to use. Should this be used instead?
Has anyone tried to do such a thing? Any hints, ideas, experiences or suggestions would be of great help.
Thanks in advance!
(4,972 Views)
I am using the Labview and CANoe together to communicate the hardware over ethernet.
To receive the data from Hardware i am using the api UdpReceiveFrom in camoe.
But i am unable to receive data from hardware.
However without Labview , the API UdpReceiveFrom works fine.
Can anyone help me in this?
(4,700 Views)
I found that There is a communication tool provided by Vector Informatik.
https://vector.com/portal/medien/cmc/speeches/TestingExpo2012_CANoe_Labview_Stein.pdf
Just my curious, why do you want to make the communication?
Certified LabVIEW Developer
GCentral
(4,693 Views)
Thanks for your reply.
Sorry but i didnt find any pdf file mentioned in your reply.
Answer : I had 6 Hardware channel on vector hardware, so i need to control the parallel communication through CANoe.
However data to transfer on hardware channel will be coming from Labview. I am using shared system variable for that purpose.
(4,689 Views)
oops the link was broken : ( Im sorry...
CAN Driver for LabVIEW® 1.6
or
Vector XL Driver - LabVIEW wrappers
GCentral
(4,685 Views)
