accessing DRAM memory through CLIP interface - looking for example
I'm using Labview 2010 SP1. NI PCIe-1473R. The help page for the DRAM (FPGA Module -> NI FlexRIO Help -> DRAM Interfaces -> Configuring DRAM with Socketed CLIP -> DRAM Memory Interface -> Random Access - 128 Bit Memory Interface) mentions at the bottom that "LabVIEW contains example VIs that read and write to the Random Access - 128 Bit memory interface." I can't find any such examples. I am looking at Hardware Input and Output > FlexRIO > External Memory; I only see 3 examples there. I am looking specifically for an example that is using the DRAM as addressable memory (not FIFO) through the CLIP interface. Can someone point me to the correct direction?
(3,275 Views)
Hello Elsayed,
I'm only seeing those same examples.  There are some other examples listed in the Vision-RIO section of Hardware Input and Output, although they may not be exactly what you're looking for.
I've also done a search of our online resources and haven't found any examples of this access.  What is the end application that you're trying to build towards?
Dave C
(3,236 Views)
It's OK, I think the Labview FPGA memories method to access the DRAM is equally efficient and its easier to work with. If you are interested about my application, I asked a question here: http://forums.ni.com/t5/LabVIEW/hdl-files-in-examples/m-p/1999777#M658378. I would appreciate it if you can assist me there.
(3,234 Views)
