access db connection error
So I'm using Access 03' and have a connection problem. I get this error:
"-2147217843
DB Tools Open Connec (String).vi->openDB.vi<ERR>Exception occured in Microsoft JET Database Engine: Cannot start your application. The workgroup information file is missing or opened exclusively by another user. in DB Tools Open Connec (String).vi->openDB.vi"
This is my connection info:
Provider=Microsoft.Jet.OLEDB.4.0;
Data Source=C:\Code\Labview\SubVIs\Test Stand\DRF_Results.mdb;
I tried this too:
User Id=test;
Password=test;
And this:
SystemDB=C:\Code\Labview\SubVIs\Test Stand\db_info.mdw
User Id=test;
Password=test;
I also have test user name and password wired to the associated terminals on the the DB Tools Open Connection.vi
If I don't use security the db works fine but IT guys want the db secured so I need to figure this out..
I also tried just using a  Database Password that wasn't user specific (no User ID in the connection file) but have the same problem.
Thanks guys!!
(3,422 Views)
So I think I found a solution. It uses the db security rather than workgroup security:
I don't need high security or different access levels so this works fine for me.
Connection info:
Jet OLEDB:Database Password=1234;
The pertinent text is highlighted.
(3,399 Views)
