about write command into register
the comand format is as follows:
this is the string I configured:
but the register for FineTuneFrequency(FTF) is signed 16-bit:
how should I write the register?? thanks!
Message 1 of 8
(5,533 Views)
Message 2 of 8
(5,514 Views)
duplicate what?
Message 3 of 8
(5,510 Views)
Duplicate post. You already asked the same time and got some answers.
Message 4 of 8
(5,505 Views)
Right off hand I would say the code you are showing should work fine. The difference between signed and unsigned is not importance -- they are both 16 bits so the command packet should build the same. Just make sure the bytes get inserted in the right order.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 8
(5,485 Views)
it says the register for FTF is 16-bit, but I use 8-bit. I don't know if my configuration is right.......
Message 6 of 8
(5,463 Views)
Please stick to your original thread. It does no one any good to have your question and answers scattered all over the place. It is also considered rude.
Message 7 of 8
(5,456 Views)
The thing is, an 8bit value will fit into a 16-bit space. Just make sure that the most significant 8 bits are all set to 0.
Mike...
LabVIEW Champion
Message 8 of 8
(5,445 Views)
