about shortcut CUT (ctrl+x)
hi all i want to ask about shortcut cut (ctrl+x), how to move the indicator on front panel but on the block diagram don't moving too ?
please see T-17 indicator, i want to move it far on the top using ctrl+x but i dont T-17 on block diagram moving too when i paste it ? how to do that ? because i`ll move many indicator like that one by one. thanks
(2,997 Views)
If you cut something, you remove the indicator on the block diagram. Why don't you just move it by dragging the front panel indicator?
(2,976 Views)
... and if you use the arrow keys to move the object, you can press Shift to move faster.
(2,952 Views)
