about limit the input characters in string with xcontrol
Hi there,
  I follow one example online to deveope a xcontrol for string input but limiting the input characters only to uppercase A to Z. I have the main code shown as follow
In the Key down event, I discard all input character with ascii code beyond [65, 90]. This seems to works but if I keep pressing down a forbidden key (e.g. %), it will show that key in the control. So how can I ban the input by long press on one key? Thanks.
(3,699 Views)
Accepted by topic author dragondriver
Maybe you should try including a "key repeat?" event. This will handle the cases when a character is added when the user holds down the key. I believe that you will just need to copy all the code from the "key down?" event.
Jeremy P.
(3,579 Views)
Or perhaps I should have suggested that you just add the "Key Repeat?" event to be handled by that case. You can have more than more event handled per case.
Jeremy P.
(3,576 Views)
Jeremy P.
Thanks. I didn't see there is Key Repeat before. I think that's what I am looking for. I will try that later.
(3,557 Views)
Hi dragondriver,
and while you're editing your VI you should use an InRangeAndCoerce function to replace two comparisons and a boolean function!
You might even think about using "LexicalClass", but that requires additional comparisons too...
#8000
(3,551 Views)
