about TDMS to Excel
当我尝试使用连接提供的vi将我的tdms文件转换为excel文件时,出现了问题。我可以单独使用 vi 成功转换。但是,当我将转换 vi 打包到 subvi 并在我的程序中调用它时,系统报告()未知系统错误,
[WJ{M4%T_0XN]F6G80{Z`81.jpg转换vi下载地址https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019VhwSAE&l=zh-CN
(1,349 Views)
I would add more code to the "UI_Convert to XLSX.vi" to find out which function causes the error.
The message in the dialog is not enough to to figure out what's wrong.
What exactly did you do when you "将转换 vi 打包到 subvi 并在我的程序中调用" ?
Is it in exe or in LabVIEW?
George Zou
(1,317 Views)
in labview now,即使我不使用子vi,而是直接调用依然会提示错误
(1,309 Views)
Since everything is in LabVIEW, why don't you debug into the "UI_Convert to XLSX.vi" to find out which function causes the error.
George Zou
(1,302 Views)
