about Case structure to handle data
HI all
As shown above
I take advantage of the FOR loop + NI-SCOPE
To crawl 5000 document oscilloscope graphics
Then graphics array to convert
After the use of the Array Max to find the maximum value of the waveform
Go on to do a compare and digital input (background)
Greater than if you enter True do processing
Less than the discarded into the next FOR loop and catch next waveform data
"less than the discarded information into the next loop"
No ideas to implement
Please greatly help ~
(2,732 Views)
You may have to use shift Registers.I have attached an example snippet
(2,725 Views)
ok
thanks for your help~
(2,686 Views)
