05-14-2004 01:19 AM
05-14-2004 03:26 AM
05-14-2004 08:07 AM
05-16-2004 06:19 PM
04-05-2006 09:53 AM
Man, this just saved me from exhausting my extensive library of profanity! I locked a group of controls and could not select them to unlock. The selection rectangle worked but I'm confused as to why the standard "click to select" does not work in this case?To unlock a control that doesn't respond to the mouse is a bit unique.
The way it works, you select the control and use the cycling arrows to
unlock. You usually can't select the control by clicking on it, you
need to make a selection rectangle, usually just a small one will do.
The selection will be more gray than the normal selection, then go
unlock it using the button. Of c
ourse if it still doesn't work, submit it.
04-05-2006 11:51 AM
11-13-2015 12:18 AM
Press Ctrl+A. All components in the front panel will be selected. Then click Reorder>>Unlock. All front panel objects will be unlocked.
