a couple of questions about listboxes
Hi guys,
as in the thread title, I have a couple of questions about listboxes.
1) When the user double-clicks on a listbox item, I write an empty array to the 'ItemNames' property and a '-1' costant to the 'Value' one. But the listbox refreshes in an unexpected way: a small grey rectangle is displayed at the position where the user double-clicked (see attached screenshot.jpg, and listbox_test.vi to reproduce the behaviour)
2) I'm able to edit a cell clicking on it twice (with a short pause between the clicks). But can I use a front panel button to have the same effect? (i.e. can I use a button to give the focus to a selected cell?). I played a lot with the'Allow Editing Cells' and 'Edit row' without success. You can look the attached listbox_test.vi to see what I did.
I've been using LabVIEW 8.2.1 on WinXP pro
Thanks in advance
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(2,740 Views)
OK... Why would you do this? This makes no sense.
This indeed seems to be a graphics artifact. It's probably due to the fact that you're modifying the listbox in the middle of an event for it. If you used a separate "Clear" button (which makes more sense than using a double-click event) and cleared the items in the "Value change" event for this button you wouldn't see the artifact.
You need set the Boolean constant to True. Smiley Wink
(2,728 Views)
In my project I use the listbox to browse an archive which has a parent/child structure. When the user double-clicks on one item, I fill in the listbox with the item children names. If the item has no children, I must empty the listbox, and so I use the empty array strings constant. Moreover I want that no items are selected, and so I use the '-1' costant. I thought this was the simplest way to do what I need...
The same graphical behaviour happens also if I use a non-empty string array (item with some children opended): the position previously selected has that gray rectangle.
Yes, I've already noticed, but I use the "Double click" event for the reason I explained.
For example, I noticed that If I move the right scrollbar, the listbox is refreshed and the rectangle disappear, but I don't know how I can use this...
Have you got any suggestion?
I don't know how I can miss this.... what a shame.....
Vix
Using LV from 7
(2,721 Views)
If you have a parent-child structure perhaps you should consider using a tree control, as it's suited for that task. In your example, how does one go back to the parent? There seems to be no way of doing this.
(2,715 Views)
I know, and I've already developed a project that uses a tree control for this purpose. But fore some reasons, I decide not to use it in this new application.
Simply double-clicking over a special item that is in the first row (like the ".." folder)
Vix
Using LV from 7
(2,693 Views)
