Zooming facility
Hi All,
I'm able to do zooming in graph controls by making graph palette option visible. This has all kind of zooming facility to zoom & view the plotted graph by making an window on the graph of my interest. But it has lacking or otherwise I do not know how to retrieve the original graph I plotted earlier before do all kind of zooms.
Instead of playing around with too many options I just like to create a Numeric control to provide the percent of magnification I need & a button to enable/activate zooming. Also I should able to retrive the original graph. I would like to get a Simplified version of native function what is available on the LabVIEW.
Hope anyone resolves my issue.
Kousy
(2,720 Views)
Hi Kousy,
Try "property node" of your graph, and see the description of these properties:
X scale > Scale fit
Y Scale > Scale fit
X Scale > Range > minimum and maximum.
Y Scale > Range > minimum and maximum
Palette > Active tool
you may want to autoscale your graphs to maintain the original view, or you may want to save the maximum and minimum values of x and y scale of your graph before zooming and then retrive those values and write them again to graph properties.
Hope this can help
(2,717 Views)
