Zoom FFT error code 1975
When using the Zoom FFT from the SVT, I receive an error code 1975 that halts the program. It intstructs me to reduce the freqency span and/or increase the lines of resolution. I would like to calculate the range of frequency and/or lines of resolution so I can limit these values. By limiting these values to acceptable numbers I won't get the error code that stops the program.
Anybody know how I can calculate this?
thanks
(3,217 Views)
Hey WanttoGolf,
I would like to replicate this. What VI's (exact names) are you using and in what order?
-gaving
(3,178 Views)
With the Sound and Vibration toolkit look at SVXMPL_Zoom FFT (Simulated).vi
Set:
Sampling frequency: 20k
# of samples : 20000
start frequency : 10
stop frequency : 10000
number of lines : 400
The rest of the settings leave at the default values.
Error 1975 - to fix
a) reduce the number of samples processed per iteration
b) decrease the frequency span
c) increase the number of lines
Tech support has given me a way to calculate the max block size (max number of samples per iteration)
(3,167 Views)
