Zeroing a load cell with Arduino
I am using a load cell curcuit with an Arduino Mega and controling an operation with LabView.  I would like to create a tear button for the load cell just like a scale would have. In order to do that, I need to read the analog value and then set that value to a variable, like "x", when the zeroing button is pressed. Then x becomes a constant that subtracks from the analog signal from the load cell. I am not sure how to set a numeric constant using a case structure controlled by a button.   I think I may be making this harder than it needs to be, but I am stuck, and would appreciate some insight.
Message 1 of 10
(6,402 Views)
It's a tare function, not tear and you would write to a shift register when the button is pressed.
Message 2 of 10
(6,395 Views)
So,  does that mean I need to use a  while loop that has a shift register inside a boolean case structure? or can it be done with just a button and a shift register?
Message 3 of 10
(6,373 Views)
I think I did it, but I don't really understand if what I did was the proper way or not.  When I tested the VI it indeed zeroed out the input like I wanted.  I used a feedback node to make it work.
Message 4 of 10
(6,366 Views)
Accepted by topic author beedoo
Try this, I don't have the arduino code enabled so I can't run it.
What it should do is on the rising pulse of pressing the zero button is set the current output to the zero value.
I've just done this quickly so no guarantee!
Message 5 of 10
(6,359 Views)
Thanks! That seems to work. I completely forgot about the other boolean operators.  It has been a long while since I last used LV.
Message 6 of 10
(6,351 Views)
Please, could you share your code in a later version? Thanks
Message 7 of 10
(6,196 Views)
Later version?  Like LabVIEW 2015?  I'm pretty sure you mean earlier version.  Attached is the same VI saved in 2011.
Message 8 of 10
(6,190 Views)
Your are right. I need the earlier version. Thanks!
Message 9 of 10
(6,186 Views)
Thanks are given with kudos.
Message 10 of 10
(6,176 Views)
