01-09-2015 08:33 AM
I had similar problem:
send data to my label printer
this is how it works:
1. install printer (in my case CAB EOS1 and give it the name: CABEOS1)
2. share printer (file and printer sharing)
3. now you can copy files (in my case JScript files) to printer by cmd -> copy /b jsfile.txt \\MYPC\CABEOS1
4. in LabView is it done in this way:
(see attached file)
BR
EWiebe
12-26-2017 03:23 PM
You can disable spooling on a per-printer basis, so turning off spooler for this printer won't influence some other printer. "Print any string" implies that anything I send to the printer through any way will get regarded by the printer as ZPL. So if you send binary data (like a Word doc or a PDF), the Zebra drivers printer will translate it as garbage. if print a content or text document and the tex file contains valid ZPL statements, the printer will translate the legitimate ZPL statements and render a name.
