Zebra Print
Hello everyone,
I hv a ZD410 Zebra printer. With this printer I am using Easy Text Report VI to print my Label. I had LabVIEW 2017 and everything was going well.
Now I am trying exactly the same ZebraCode but with LabVIEW 2020. The graphic in the Label is not printetd completely. Only 1mm of the graphic is printed. I reinstalled LabVIEW2017 and everything is going well again.
The problem is that I cannot use LabVIEW 2017 because I used Map, which is not available in 2020
I am wondering had already faced something like this?
Thank you
(1,601 Views)
Do you have the latest Zebra printer driver? What exactly are you trying to print? Can you post and example VI with a sample label you are trying to print?
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(1,585 Views)
The printer is working right with LabVIEW 2017 or any Wndows editor. I found a difference in New Report.vi between LabVIEW 2017 and LabVIEW 2020. in LabVIEW 2020 there is no NI_Standard Report.lvclass. I tried to copy it from 2017 to 2020 but it didn't work.
(1,517 Views)
