You must install LabVIEW run-time engine on the computer you run the application
When I build an executable application, I get a warning message says,'You must install LabVIEW run-time engine on the computer you run the application'
How can I solve this problem? Thanks.
(2,817 Views)
It is not a problem. It is a requirement that you install the run-time engine so the app builder is just reminding you of that fact. When you create the installer for your app, you can optionally choose to have the run-time engine as part of the install.
(2,817 Views)
Install LabVIEW run-time version (1 CD) on your computer before you run the .exe.
(2,817 Views)
