YOKOGAWA WT3000 Store Instruction
The period of store hsas be set to 1s.It means that the datas of U,P and I are recorded to  memory(or register?) once a second.Because I don't know where they are stored  ,I try to read the display data by delay 1s.After datas are read, they will be sent to an Excel file to calucate.Then the next second,datas will be read and sent to file.I can't make sure that the datas I read are the results per second.
If you used to try it and successed or know how to read the store datas from the memory(register?) of WT3000,could you give me some advice?
Thank you!
(3,191 Views)
Hi J,
I never worked with that special device, but I guess you could ask Yokogawa about their devices.
And you could read the manual which came with your device to find the answers you need…
When there is a STORE command then there usually is a READ or FETCH command…
(3,169 Views)
Dear GerdW,
Thanks for your reply.
I'm waiting for the reply  of  Yokogawa.
I also can't find the commands in the Manual .
(3,163 Views)
Hi J,
Well, there is chapter 6 with all commands!
See the section on WAVEFORM commands…
(3,158 Views)
Hi,GerdW
Thanks for your rely.
Because I think WT3000 is in numeric mode(or called other name,but not waveform mode ) ,I never read the waveform command.
Thanks for your suggestion again.
(3,129 Views)
