YAML Parser
I just got a YAML file I have to parse. Before I "roll my own" Does anyone have a parser?
(6,001 Views)
JSON may be a valid YAML parsing thingamjijjy.
"Should be" isn't "Is" -Jay
(5,965 Views)
Can you explain? YAML looks nothing like JSON. How might I use a JSON parser to read in a YAML doc?
(5,954 Views)
How do they look?  Does it effect how you show them or what the data is?
We cannot tell unless you show a data file or attempt to use one in LabVIEW code you show.  So, you want "Specific "answers?  Geneneral information won't work.
(5,952 Views)
Googling "LabVIEW YAML" resulted in this being the first link - https://www.vipm.io/package/nicolas_bats_lib_yaml_parser/
Santhosh
Soliton Technologies
(5,948 Views)
How do they look?
Using examples from wikipedia. YAML looks like this:
--- # Sequencer protocols for Laser eye surgery
- step:  &id001                  # defines anchor label &id001
    instrument:      Lasik 2000
    pulseEnergy:     5.4
    pulseDuration:   12
    repetition:      1000
    spotSize:        1mm
- step: &id002
    pulseEnergy:     5.0
    pulseDuration:   10
    repetition:      500
    spotSize:        2mm
- step: *id001                   # refers to the first step (with anchor &id001)
- step: *id002                   # refers to the second step
- step: *id002
And JSON looks like this
  "firstName": "John",
  "lastName": "Smith",
  "isAlive": true,
  "age": 27,
  "address": {
    "streetAddress": "21 2nd Street",
    "city": "New York",
    "state": "NY",
    "postalCode": "10021-3100"
  "phoneNumbers": [
      "type": "home",
      "number": "212 555-1234"
      "type": "office",
      "number": "646 555-4567"
  "children": [
      "Catherine",
      "Thomas",
      "Trevor"
  "spouse": null
Note all the curly brackets in the JSON and the dashes in the YAML
I don't understand this question. I'm not trying to "show them" I'm just trying to get values from a string. For the example above, I might want to output an array of a cluster of "pulseEnergy" (a dbl) and "pulseDuration" (an int). I think this is what people commonly mean when they try to parse a file.
(5,938 Views)
