Y-axis string values
I created an XY graph with Y-axis values representing 9  different channels. See attached screesshot.
For example:
1 represents Channel27
2 represents Channel45
etc..
What I would like to do is to have the name of the channels written directly on the Y-axis instead of numbers.
Something similar to what has done here for 3D stem plots: http://forums.ni.com/t5/LabVIEW/3D-Stem-Graph-String-based-Axes/m-p/2589885/highlight/true#M779040
Problem is that I can't find a property similar to Value Pair Array in 2D graphs.
Does anyone have a suggestion?
Thank you!
MG
(3,743 Views)
Accepted by topic author MG70
Hi MG,
easy solution: hide the Y axis (both values and label) and show the plot legent. Label your plots according to your channel names…
More advanced solution: hide the Y axis and place some string indicators in that area. Move the string indicators to their exact position and output the channel name in them…
(3,727 Views)
 Thank You GerdW!
 I like the workarounds you proposed and the graph looks very nice!
MG
(3,711 Views)
