Xpath
hi
I need help to use XPath, take this code of "net" and transforms it into LabVIEW code, but the result I get is not desired
 http://rapidshare.com/files/234470020/Xpath.zip.html
Original Post (http://forums.ni.com/ni/board/message?board.id=6170&thread.id=9769)
(6,538 Views)
I hope this example helps, I took it straight (after pasting the contents of my subVIs in one VI for demonstration) from a project of mine.
I only have a beta installed at home so you'll have to make do with a screenshot of the code.
Message Edited by andre.buurman@carya on 05-19-2009 08:44 PM
André (CLA, CLED)
(6,516 Views)
Accepted by topic author ANTONIO_GARCIA
As far as the original code is concerned, it wasn't a direct implementation of the .NET code. You need a loop to populate the matches for your XPath. See attached modification.
(6,509 Views)
