Xilinx FPGA DDS Compilation Error
Hi;
I am working on a project which i need to use Xilinx FPGA DDS Compiler, but i don't know why I am encountering with the
following error. i am using LabView 2015, while Xilinx 10.1, xilinx 14.7 compiler and Xilinx 14.4 Vivado tools are installed as add-on.
"Error 7 occurred at Open/Create/Replace File in MD5Checksum File.vi->niFpgaXIPINIsFuse2Needed.vi->niFpgaXIPINConfPage1.vi
Possible reason(s):
LabVIEW: File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
C:\NIFPGA\iptemp\xipin8EE3814B93AE4DDF942A4AA8EE9C6515\DDS_Compiler_F6E9D9D81C784E0EAFE277F741BA8D45.vhd"
any help would be appreciated,
best regards.
(3,775 Views)
You cannot use File-VIs within an FPGA-VI, there's no direct access from the FPGA chip to your HDD device.
Regards, Jens
Kudos are welcome...
(3,754 Views)
thank you for your reply.
but this error occur while Xilinx compiler tries to compile a DDS compiler on an FPGA target VI.
I have found the right path, but as you can see it is kind of a temporary Xilinx compilation file.
(3,730 Views)
(3,715 Views)
