Xflow - Program par returned error code 3. Aborting flow execution...
Hi Donovan
I'm having the same problem as the previous commenters.
could you please post the Spartan modul again to download?
thank you very much
Message 11 of 22
(2,606 Views)
It should be available again here.
Donovan
Message 12 of 22
(2,582 Views)
Hi Donovan,
Is it possible to get this file once again ? I'm trying to implement a SRAM with a CLIP node and I'm getting the same error...I'm also using a Spartan 3E dev board.
Thanks !
Regdards,
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
Message 13 of 22
(2,508 Views)
Donovan
Message 14 of 22
(2,476 Views)
I have run into what seems like the same problem as others in this thread. I'm trying to compile with the FPGA module in LabVIEW 2009 and get the error Xflow - Program par returned error code 3. The program compiled fine until I added a signal generation vi, so it sounds like the same issue. Would it be possible to make the modified compile server available again.
Message 15 of 22
(2,423 Views)
Donovan
Message 16 of 22
(2,418 Views)
Hi Donovan, could you upload the modified server again, cause i have same problem.
another question, whether i can speicify the address when using ddr sdram in labview ?
I'm using spartan 3e starter kit with labview fpga module.
Message 17 of 22
(2,353 Views)
Hi Donovan,
can I have the file, too...please!
Why do you don´t let the file on the FTP-Server?
regards
Holger
Message 18 of 22
(2,316 Views)
"To allow this VI to compile, navigate to the  <labview>\rvi directory and rename compileServer.exe to compileServer.exe.bak.
Copy the attached executable to the same directory.
Open compileServer.ini and add check for a section called [LabVIEW]. If the section exists, add the token XIL_PAR_KEEP_BRAM_MULT_APART=0 to this section. If not, create the section and then set the token."
Da Helmut
Message 19 of 22
(2,303 Views)
thanks a lot !
it works!
Message 20 of 22
(2,280 Views)
