Xcontrol bug with reinitialize to default value
If you right click and select reinitialize to default value on a xcontrol. The data change event will not be fired with in the xcontrol. A value change event will be fired from the xcontrol though.
Attached is an example. The xcontrol is basically a numeric with a counter for data change events.
In the example vi is a numeric that changes the value(signal) of the xcontrol. And another numeric that changes whenever the xcontrol has a value change event. It works as expected unless you reinit to default, which doesn't change the display of the xcontrol (because it doesn't fire a data change event), but does change the numeric that reflects value change events.
Matt W
(2,584 Views)
Hello Matt,
This was reported to R&D (# 4GPD8CUD) for further investigation.  It looks like the data is being reinitialized, but then the control is not receiving the event to update what the data is in the control.  I have tried to look for a way of changing this behavior, but I cannot find an event that would update the control like it should be updated.  I thought there might be a different event for the reinitialization, but I couldn't find one.  I have made a report on this for R&D to look into more closely.
Brian Coalson
Applications Engineering
Brian Coalson
Software Engineer
(2,560 Views)
