XY - plot using parameter related colors
I would like to create an XY-plot, similar to the standard one in
labview but now with 3 columns as input: the standard X and Y
coordinates and a third one related to the colour of the individual
points.
How should I build a fast VI for obtaining these coloured parameter
plots?
Koen
(3,152 Views)
Not sure if you CAN do this with the XY-plot object. However, what you can
do is create a 3D plot, viewed directly from above, and the third column
determines the height of each point. The 3D plot can be set to be
colour-coded for the different heights/Z-values.
I've only used the 3D plotting with matrices, so you may have to convert
your 3 column array to a square matrix first.
3D plots are only in Labview5- you don't state what version you're in.
I guess an alternative way would be to use the picture stuff and make a
bitmap that you then display, but I've never played with that stuff.
Koen Maertens wrote in message
news:394A3155.2616F0A1@agr.kuleuven.ac.be...
n
> points.
> plots?
> Thanks,
> Koen
(3,152 Views)
Intensity graph where you would use your third aray for the colormap.
"Koen Maertens" wrote in message
> points.
> plots?
> Thanks,
> Koen
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(3,152 Views)
