XY graph interpolation
Hello all,
I am new to Labview. Probably, this is simple question, but I am really stuck on it. I have a XY graph (temp Vs resistance for thermistor; the curve looks like decay fucntion), for each unit degree there is corresponding Resistance but I want to get corresponding resistace for some decimal temp(like 10.5 or 18.1 C) using some kind of interpolation. Any kind of help here. Thanks in advance.
Message 1 of 9
(7,365 Views)
You did not include the datafile.
Message 2 of 9
(7,363 Views)
Accepted by topic author akc
Try this. (assuming you want linear interpolation).
Message 3 of 9
(7,357 Views)
Thanks for reply.
Here is the data file. Sorry, I couldn't upload the CVS(comma delimited file).
Message 4 of 9
(7,354 Views)
Since your T values are equally spaced and coincide with the array index, you can simplify significantly.
Message 5 of 9
(7,334 Views)
Yap thanks for the advice and solution. One more question to bother you. sorry. Now I have to interpoate Resistance vs Temp i.e for a give resistance what is the tempeature. In this case the resistance is not in equal interval. How should I deal with this problem?
Again thanks
Message 6 of 9
(7,329 Views)
And yap I tried by switch the columns from your previous VI and seems like it doesnot work if x-is resistance so as to get y-value (i.e temp). Any suggestions!!!! Thanks.
Message 7 of 9
(7,325 Views)
You are lucky that the mapping is unique. You can use "threshold array" in the same way, but since you data is decreasing, negate the array and the search value to get the correct result. Check the online help.
Message 8 of 9
(7,324 Views)
Thank you for your help. Really appreciated!!
Message 9 of 9
(7,322 Views)
