XY graph inside event structures
I'm having some problems with XYgraphs inside event structures.
As you can see if you run the vi, every time I click on a button (trigger an event, for example OPEN/CLOSE a graph)
the XYgraph restart and all the past plot is lost (it restarts without any information stored).
Do you know some possible way to avoid this problem?
Thank you very much for your attention.
(2,945 Views)
Accepted by topic author ther1ng
The reason why this is happening is that in those other event cases you are passing out an empty array of timestamps. You are using feedback nodes for the temperature and pH data, but you are using a shift register for the time stamps. In the event cases for the Boolean controls you are not wiring through the array, and thus the event cases are passing out the default value for an array, which is always an empty array of that datatype.
(2,928 Views)
Precisely! Many thanks mercurio.
I replaced the shift register with a feedback node inside the event case and it's working fine right now Smiley Wink
(2,905 Views)
