XY graph export image JPEG color PB
Dear.
How save a graph in JPEG with a simplified presentation and keep the line color on the picture like "Invoke node: Export images" .
To have  JPEG image I used the "invoke node: get image" and I put a 1 on the color to simplified the presentation but it's don't keep the line color.
I have seen this post who speek about this subject:
In the zip there is a the project to show the difference between the tow "invoke node"
I someome can help me..
Massif
(12,206 Views)
I answerded your mail, is the solution right? If it's the case could you share it in here ?
Regards
Richard Keromen
(12,166 Views)
Thank you for your answer.
I would like a picture from a graph with:
- black and white background
- the line in colour.
- the extension jpeg
I explain all in the e-mail.
I will post an other message when we find the solution.
Regards
(12,163 Views)
Hi Massif,
if you set the picture depth to 1 you can´t have any color in it. Use 24 bit and change the background color. Or another solution, save your picture as bitmap, open it and save it as jpg. See the attached example.
Mike
Message Edited by MikeS81 on 04-21-2008 09:52 AM
(12,160 Views)
  Hi Mike
Thank you for your help. I will try to open the bmp image and save it to jpeg.
Thank you also to Richard and the good LabView support
Regards
Julien
(12,153 Views)
Is there any way to have the saved BMP or JPG file include the minor gridlines as well?
(10,851 Views)
You will find here a good thread : export simplified image invode node
Steve M.
(10,819 Views)
