XY graph Yscale.NameLbl.text does not update when vi is called as subvi
BG,
No worries.  I'm glad you got it working.  If you do figure out what you changed that was causing problems before, you should post it so I can try to replicate the problem.
Christina
Message 11 of 12
(799 Views)
Accepted by topic author bill_gilbert
OK, almost a year later, I found the problem! It was too late to roll out this version, so they're just doing it now, and the problem has reappeared. The unit value is passed into a front panel control from the calling vi. On the versions that don't work, that control is HIDDEN, and the RingText.Text property read doesn't always work. On the version I posted here it's visible. The versions with the hidden control may not always screw up, but making the control visible seems to cure the behavior.
Message 12 of 12
(730 Views)
