XY Graphs
I am using a Sine wave to simulate what will eventually be an input from a pressure transducer. I have placed a Waveform Graph on the front panel to give a graphical output.
What I now want to do is to change this Waveform Graph to an XY graph. The X-axis of this should record time in seconds and the Y-Axis Pressure (in the simulated case, this is the amplitude of the sine wave).
When I run this, the scale on the XY graph is huge (3E+9) It is setup to auto scale. Also no plot trace is visible.What I want is an X-Axis which will increase its scale so as to record the Data over time. Thus giving the entire experiments pressure on one plot.
How can I solve this problem?
Cheers
(5,379 Views)
How do you expect the For Loop to end if you run in an infinite number of times?
(5,374 Views)
I specified a finite number of loops (10) and got what is described above.
Ignore the infinite symbol!!:smileytongue:
How can I get the desired output?
(5,366 Views)
Post your updated VI so we can play with it.
(5,355 Views)
Why are you using a graph at all?  It sounds like a job for the chart.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(5,331 Views)
Will the chart give me a continuous output once connected to a 'real' data source? (Thermocouple/Pressure Transducer?
Cheers
(5,319 Views)
You could create a simulated device in MAX and create a dummy channel, that dummy channel will put out a sinewave since it is simulated.  Then put a DAQmx read on the block diagram to read the dummy channel you made.  Set the read for a single channel waveform and hook it up to a waveform chart.  That will give you a sinewave with a timestamp which should be similar to the way you are going to be reading the data for real.
Message Edited by _Bryan on 05-28-2010 05:12 PM
(5,305 Views)
