XY Graph
I am using an XY graph to plot data acquired from a sensor in real time. The sensor outputs the data in three axes, X, Y and Z. I am plotting all three axes data in the same XY graph. However, sometimes the graph shows only 2 plots, although the sensor streams data in all three axes, and the amplitude axis of the graph spans upto about +/ 500000 although the data values are within about +-180. Why might this be? Kindly advice
(2,764 Views)
Could you please post your code?
thanks,
Norbert
Norbert
Expert: Geometry
(2,762 Views)
