XY Graph with No Lines, Just Points?
Hi All,
I want to build a Pressure vs. Temperature graph.  This should be a standard XY graph, but I just want to see the point scatter with no lines connecting the points.  Is there a way to eliminate the lines between the points (or make them invisible)?
Thanks!
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(4,896 Views)
Accepted by topic author diarmaede
You can do it in graph properties. Right click on graph and select Properties. Go to the Plots tab.  Select a point icon (anything other than <none>) in the third column of icons. Next select the top-most selection in the fourth column. It's the symbol with the plot points but no lines. This will give you waht you want.
(4,891 Views)
How the heck did I miss that?!  Thanks!
Forbes Black
(4,887 Views)
