XY Graph question - Context help?
I am looking and not seeing anything, but is there a way to add context help captions on the buttons of the Graph Palette for an XY Graph?
Something that I can use so that an end user can hover over a button and get a description of what each button does?
(2,494 Views)
Hi DBISI,
I don't think there's a way to edit the graph palette button properties…
You could use the MouseMove event to detect mouse movement over the graph. Then you could read the mouse position and determine which graph element is below the mouse pointer. Based on this information you could show your own (kind of) context help using a string indicator, either in a separate VI to mimic the hover effect of the tooltip or e.g. at the lower border of your UI window (or any other appropriate position)…
(2,488 Views)
Is there a way to change the graph palette from horizontal to vertical?
If it cannot be edited then no. If the buttons were vertical I could at least put text beside it manually.
Another thing I am trying to do right now i figure out what the minimum and maximum X values are, so that if I am zoomed in I can move the cursor to within the new window.
(2,477 Views)
Accepted by topic author DBISI
Hi DBISI,
No.
Another suggestion:
Create your own graph palette using customized buttons. Then you have full control over all items, but need to manipulate the graph using property nodes…
Use property nodes of the graph!
(2,450 Views)
That's doable... Just a shame some of the built in tools are missing little things like that.
I already have a tool to reset the zoom to the fit to window and put it back in cursor mode.
I have been looking at the property nodes for a while, I just haven't identified the correct one yet. My cursor index is say 150 while the X min and max are in the ten digits... My x scale is set to show time absolute time instead of index.
(2,443 Views)
Hi DBISI,
The cursor position is given as index of the plot sample.
The x axis values are timestamps converted to seconds, aka seconds since LabVIEW epoch…
(2,438 Views)
That makes sense. I should be able to extrapolate what I need from that to get the proper index.
Thanks.
(2,435 Views)
