XY Graph cursor problem after get image
Hello
I'm using Coursore for my XY graph.
it works without any problem until i Get XY Graph image after tha when i move cursor i see These white lines !
(4,097 Views)
To make the white lines go away do you have to stop and restart the application? Are you using the method to get the image? How is it configured? What happens when you refresh the data in the graph?
We really need to see some code.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,976 Views)
Hello
This How I Get The image :
When i refresh white lines disapare.
(3,953 Views)
Well, it seems like you have two options:
1 Refresh the graph after exporting its image
2. Make the graph background white (looks better anyway)
Mike...
LabVIEW Champion
(3,917 Views)
is it kind of bug ?
I'm using Build XY graph .How can i refresh graph without excuting this function ?
(3,909 Views)
I would say that yes if verified it is a bug. You don't show where the data is coming from. You shouldn't be using an Express VI do something this simple.
Mike...
LabVIEW Champion
(3,866 Views)
Hello
The data is reading from Servo Drive and Loadcell Transmiter through Serial port.
(3,669 Views)
